I seem to have an issue with the time periods in the reports.
When i run a report on hosts that are 100% up they are working and the report is correct when the check time is 24 x 7.
when i run the same report but i want to add a time periode " lets say from 06:00 to 23:00 the result gives me a 100% down status.
Reports using the " Report Time Period" do not work
nagios-retail
benjaminsmith
Re: Reports using the " Report Time Period" do not work
I just did a quick test of this on the latest version, and I'm not able to repeat the behavior. What version of Nagios XI are you using?
Also, if you can provide screenshots of both reports with the advanced settings shown (see screenshot below), I can try to re-create it.
Thanks!
Benjamin
Thanks!
Benjamin
