Hi Team,
we found one issue in nagios host check.
we have configured host check should happen every two min.
Retry interval 1 min
max check attempt 1 min
i) In attachment 1 state history says at 2021-03-22 21:57:56 its down.
As per config retry interval should happen 2021-03-22 21:58:56
but in our case it was happen very quickly and that is 2021-03-22 21:58:04
why next check happen quickly that too its only 10 sec diff ???
Host check understand.
informatica
benjaminsmith
Re: Host check understand.
Hi @informatica,
Let's make sure the system time and PHP time are in sync. Go to Admin > System Config > System Profile, select the View System Info button and scroll down to the Date/Time section. Let me know if there are any issues there.
If that's not the case, I'd like to get the nagios logs from 3-20 to 3-23, they are in the following directory. Please upload or send them over in a private message.
Benjamin
/usr/local/nagios/var/archives
Benjamin
informatica
I sent PM to your inbox
benjaminsmith
Thanks for the logs. Those mirror what's in the report. Can you send over the system profile? I would like to check the object configurations and system logs.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Regards,
Benjamin
Regards,
Benjamin
