Nagvis: Maps hide hosts under geografical map
FCC_Nagios_Support
Post by FCC_Nagios_Support »
I am a beginner in Nagvis.
I try to picture a geographical world map with my hosts represented on it.
But:
Whe I create the map and I add the host/equipment, this one is hidden by the geographical map under it.
How can I represent the map and place hosts/equipment over it in zones.
What It happens is that when I added one host, this one appear over and hidden by the map
Many Thanks
ssax
Dreams In Code
Re: Nagvis: Maps hide hosts under geografical map
Post by ssax »
You would need to set the z index value to be higher than the background image when adding the objects:
The z option defines the order of icons which are stacked on top of each other. The highest value will be displayed on top. The background image has the value of 0. So valid values should be above or equal 1. Note: To prevent conflicts with the header navigation you should keep this value below 100..
Taken from here:
http://docs.nagvis.org/1.9/en_US/map_co ... ption.html
Here's a good z-index primer:
https://developer.mozilla.org/en-US/doc ... SS/z-index
FCC_Nagios_Support
Hello
I can not, see attached
The map is the background I sopose
FCC_Nagios_Support
This case run but I can not remember the reason
ssax
Dreams In Code
Post by ssax »
Please PM me the non-working map file from this directory:
/usr/local/nagvis/etc/maps
