We used check_oracle_health plugin on XI 5.7.3 and encountered the problem as attachment.
[nagios@Nagios19 ~]$ /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/18.5/client64/lib ORACLE_HOME=/usr/lib/oracle/18.5/client64 /usr/local/nagios/libexec/check_oracle_health --connect '' --username '' --password '' --mode sql --name="select count(*) from nagios.alert_history where ORIGINATING_TIMESTAMP > trunc(systimestamp - 30/(24*60),'mi') and ORAERROR1 not in (select ORAERROR1 from nagios.oraerrwlst)" --warning 0 --critical 2Code: Select all
UNKNOWN - got no valid response for select count\\(\\*\\) from nagios.alert_history where ORIGINATING_TIMESTAMP \\> trunc\\(systimestamp - 30/\\(24\\*60\\),\\'mi\\'\\) and ORAERROR1 not in \\(select ORAERROR1 from nagios.oraerrwlst\\) - ORA-00911: invalid character (DBD ERROR: error possibly near <*> indicator at char 12 in 'select count<*>\\(\\*\\) from nagios.alert_history where ORIGINATING_TIMESTAMP \\> trunc\\(systimestamp - 30/\\(24\\*60\\),\\'mi\\'\\) and ORAERROR1 not in \\(select ORAERROR1 from nagios.oraerrwlst\\)')Is there any possible for this issue as a bug between them? For your information, the version of DB is 11.2.0.4.0 and OS version is CentOS 8.2.
P.S. I would PM profile when any replies available.
Please advise.
Thank you!
