my nagios xi is acting up as i cannot apply any new configurations, i get the erro below
Error: Could not find any host matching 'DXASMPP4' (config file '/usr/local/nagios/etc/services/DXASMPP4.cfg', starting on line 219)
Error: Failed to expand host list 'DXASMPP4' for service 'Swap Usage' (/usr/local/nagios/etc/services/DXASMPP4.cfg:219)
Mind you i have deleted all services and hosts associated with the above error but i still get the error after i run apply configuration, i have also gone through file manager, deleted files, written configs and restarted nagios but i stll get same error, not sure what to do anymore. please see my profile attached
cannot apply configuration on nay new configs
Re: cannot apply configuration on nay new configs
Hi
Please run the repair database script below:
Now, try the file manager, deleted files, written configs, verify files then Apply Configuration.
Regards,
Vinh
/usr/local/nagiosxi/scripts/repair_databases.sh
Regards,
Vinh
you have a couple extraneous files that need to be removed
run the following
then the config should apply or give you an appropriate error
run the following
rm -f /usr/local/nagios/etc/import/*Re: cannot apply configuration on nay new configs
that worked, thanks
benjaminsmith
Great! We'll go ahead a close this out, but feel free to open another post if you have any new questions.that worked, thanks
