Error migrating from Nagios Core
SoporteGSID
Post by SoporteGSID »
I am migrating from Nagios Core 3.2.3 to Nagios XI 5.8.2 and always shows the following error:
X Bundled and transferred Nagios Core data
X Prepared Nagios Core data for import
X Imported Nagios Core data into Nagios XI
X Applied new configuration in Nagios XI
Error: Could not transfer the configuration.
The script exited with an error on remote system:
This system is not registered with RHN Classic or Red Hat Satellite. You can use rhn_register to register. Red Hat Satellite or RHN Classic support will be disabled. Error: Cannot find a valid baseurl for repo: base
Both systems are CentOS, one with CentOS 6.9 (Nagios Core) and other with CentOS Stream 8 (Nagios XI). Any ideas?
benjaminsmith
Re: Error migrating from Nagios Core
Post by benjaminsmith »
Hi @SoporteGSID,
This is most likely the result of the repos being out of date on the Cent 6 system.. Does the system have access to the repos? If not it will be necessary to use the CentOS Vault repositories.
See: https://www.getpagespeed.com/server-set ... 6-went-eol
If that's not the issue, It may be due to a corrupted yum cache, run the following commands then try once more.
yum clean all
rm -rf /var/cache/yum/*
Also, make sure you have python installed on the target system.
python -V
--Benjamin
SoporteGSID
Hi Benjamin, thanks for your reply!
You were right, the repos were out of date, I didn't think the CentOS version could be a problem (or the repos in this case). Following the instructions at GetPageSpeed I've been able to migrate to Nagios XI.
Again, thank you very much for your help.
dchurch
Post by dchurch »
Glad to hear you resolved it! Locking thread.
If you have any additional issues, feel free to make a new thread.
