Hello Everybody.
I'm new in Nagios and i have a problem that i think is very simple for you but I can't get through it. I want to start using this plugin:
http://exchange.nagios.org/directory/Pl ... ck/details
but I don't know how to do it. Should I put a file in the libexec directory or execute the script ??? And what should I put in the commands.cfg file and file in with I hold my service definitions???
Thank you for your help.
Marcin.
Nagios plugin installation
Re: Nagios plugin installation
You should put the file in your libexec directory with executable permissions. Following that, you need to create a command definition (which is shown on the plugin's page) before you can use it. That page also shows example service definitions.
