G 'Day Nagios Support,
So I need help trying to create a workaround for an environment in which I have absolutely no access to due to a major overlap of a private subnet. The hosts in that subnet can successfully direct passive checks to our F5 vip which is the front-end to our Nagios XI environment. The problem I have is trying to utilize custom check where I query the Last Check value to determine if my __HOST__ host check is updating the host within Nagios. Seems like when the host check exceeds the time differential for whatever reason (most likely freshness) fires the dummy command (xiwizard_passive_host) and updates the Last Check value and of course clears the event.
I am open to any ideas...trying to get a tool server in that environment is an option but not immediately and I would really like a way to really make a Passive Host Check work...maybe I am just missing something and just need a nudge.
Any and all help greatly appreciated.
Danny
@onegative
Passive Host Check
Re: Passive Host Check
How specifically are you doing this?The problem I have is trying to utilize custom check where I query the Last Check value to determine if my __HOST__ host check is updating the host within Nagios
If the freshness threshold is exceeded there's no way to stop it from doing that without disabling/or increasing the freshness thresholds or creating your own check command that freshness will run that does/checks for something else.
So after chasing other rabbit holes...I finally figured out that our problem...basically we used the API to pull the hoststatus and needed to read the last_check parameter but the person who wrote the python code used status_update_timeinstead which after the service alert would update the value thus clearing the alert. So once I determined this wrong parameter query and pointed to last_check parameter it started working as expected.
You can close this thread and thanks,
Danny
Danny
Locking threadonegative wrote:So after chasing other rabbit holes...I finally figured out that our problem...basically we used the API to pull the hoststatus and needed to read the last_check parameter but the person who wrote the python code used status_update_timeinstead which after the service alert would update the value thus clearing the alert. So once I determined this wrong parameter query and pointed to last_check parameter it started working as expected.
Danny
