Repository setup for Red Hat Satellite
enderson_rhb
Post by enderson_rhb »
Would like to know is there any way to setup the Nagios Repo in Red Hat Satellite? Since we still trying to explore any way to connect the repo to Red Hat Satellite and skip the epel release connecting to Intranet.
dchurch
Re: Repository setup for Red Hat Satellite
Post by dchurch »
The EPEL repository package itself isn't required by Nagios XI, just some of the packages in EPEL.
If Satellite provides those packages, it should be good to go. Otherwise you can add EPEL 8 to Satellite using this tutorial.
