Hello team ,
Below are the requirements -
1.can Nagios Xi integrated with solar winds tool ?
2.Can Nagios Xi integrated with any asset management tool ?
3.Management Consoles Integration like Anti virus Console, ESRS ? Is it possible
Nagios xi integration
benjaminsmith
Re: Nagios xi integration
For the first question, we currently do not have integration as our products are an alternative.
Reference: Nagios XI is your SolarWinds Alternative Monitoring Solution
For questions 2 and 3, currently, we do not have any built-in integrations. However, Nagios XI does have a robust REST API to connect to, and depending on the application that might be an option.
Let us know which applications you are currently using and I can look into this further.
Regards,
Benjamin
Regards,
Benjamin
