Is it possible to configure alerts in Nagios if the utilization value is not in percentage ? In our system we have some memory utilization monitor that give output in MBs and KBs but not in percentage of utilization, can we configure alerting for such cases ? If yes then how this can be done ?
Regards,
Preethu
Nagios Xi monitor
Re: Nagios Xi monitor
Sorry, no that's not currently possible. Warning and critical thresholds are interpreted by the NCPA listener in terms of percentage.
See here for where NCPA interprets warning and critical thresholds.
Thanks for the update.
This is a network device and added in Nagios via SNMP, and the device shows memory utilization as value (like kbs and mbs)in this case is it possible to set alert ?
Regards,
Preethu
Regards,
Preethu
check_snmp supports some arguments -w and -c for warning and critical. Try plugging in those to the service check command.
For example:
I'm not sure why I assumed you were using NCPA. My mistake.
For example:
check_snmp -H 192.168.1.100 -o DEVICE-MIB::AverageReceiveSNR.0,DEVICE-MIB::CurrentNoiseFloor.0 -w 10: -c 15:
I tried the given argument in run check command and I am getting unknown object identifier error.
Regards,
Preethu
Regards,
Preethu
Try going through the "SNMP" wizard to set up the device. It'll ask you for warning/critical thresholds as you go thru it.
I was using the same wizard for adding this SNMP enabled network switch. I updated memory OID and gave critical and warning threshold. But it is showing memory utilization in bytes not in percentage. Is there any way we can change it as percentage of utilization instead of its current memory utilization value.
Regrads,
Preethu
Regrads,
Preethu
If the value returned from SNMP is an absolute bytes value, then that's the only thing that can be checked.
If you find a different OID that returns the value as a percentage, then you can use that, and set a threshold appropriately. Otherwise, there's just not enough data returned from the SNMP command to be able to calculate percentage.
You could just specify the threshold in terms of absolute byte value.
