Command line to get audit logs from xi_auditlog
xlin125
Post by xlin125 »
We have Nagios XI 2014R2.7 on RHEL6, and we also have Nagios XI 5.2.3 on RHEL6 and Nagios XI 5.4.8 on RHEL7.
On Nagios XI 2014R2.7, both MySQL and Postgres are used. We can run the command "echo 'select * from xi_auditlog;' | psql nagiosxi nagiosxi" to get the audit logs in the table "xi_auditlog".
On Nagios XI 5.2.3 and Nagios XI 5.4.8, MySQL is used but Postgres is not used. What is the equivalent command that can be used to get the audit logs in the table "xi_auditlog"?
benjaminsmith
Re: Command line to get audit logs from xi_auditlog
Post by benjaminsmith »
Hi
The table structre is the same, but connection commands will change from postgress to mysql.
echo "select * from xi_auditlog;" | mysql -h 127.0.0.1 -uroot -pnagiosxi nagiosxi
Let us know if you need further assistance with the query.
Also, RHEL 6 is EOL and not supported at this time. I would recommend planning a migration for those systems. The Nagios XI license policy does allow for 3 separate activations (production, test and backup) to help make this a smooth transition.
Reference:
Migrating Nagios XI to a different Server
Regards,
Benjamin
xlin125
Post by xlin125 »
@Benjamin, thanks for the quick response.
I tried the command that you provided, and received an access denied error:
$ echo "select * from xi_auditlog;" | mysql -h 127.0.0.1 -uroot -pnagiosxi nagiosxi
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
Any suggestion to resolve this issue?
benjaminsmith
It looks like the default database passwords were changed on this system. You can retrieve this information by inspecting the following file.
cat /usr/local/nagiosxi/html/config.inc.php
For more details, we have a useful guide with detailed instructions on changing the default passwords, take a look on page 3 for the database settings.
Nagios XI How to Change Default Passwords
If that's not it, try logging in directly and then running the query.
mysql -u root -p
use nagiosxi;
Let us know if you get it resolved.
xlin125
Post by xlin125 »
Yes, the default database password was changed during the Nagios XI installation on this system. I found the password, and all looks fine. Thanks!
benjaminsmith
Hello @xlin125,
Excellent! We'll go ahead and mark this as resolved.
Have a great weekend.
