we use a Nagios4 on Debian installed via apt. The last years we're used to monitor remote load of our linux servers via snmp load check. We figured out that theres a bug with warning and crit levels so want to switch to monitor load via check_nrpe and check load.
We use pnp4nagios for visualization but there is a huge difference between how the check load data is visualized on the local nagios system vs. the remote system. here are two screenshots.
This is how it should be and is on the local nagios4 server:
and this is how it is when checked via check_nrpe on a remote system:
Best, patrick
