I am trying to install Nagios XI on Windows Server 2012 R2 Hyper V. I followed the steps in this PDF, but an IP won't show up.
https://imgur.com/a/Yndb9uI
I've tried different virtual switches, that all work with other virtual machines on the same Hyper V. I've tried no virtual switch. I've tried enabling the VLAN ID. I've tried uninstalling the virtual machine and reinstalling it.
Any help would be appreciated.
Thank you,
Michael
Hyper V install won't give IP
Re: Hyper V install won't give IP
Can you post the rest of the virtual network adapter settings? Such as, DHCP ranges, network mask, port forwards, etc?
Then can you type this inside the virtual machine and post the output (screenshot is fine)?
ip addr
ip route
cat /etc/resolv.conf
ipconfig -aIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
sternbergm
Where do I find the DHCP ranges, network mask, port forwards, etc? Here are the settings for the virtual switch from Hyper V.
https://imgur.com/a/34MPfdK
Here is the output from the commands in the virtual machine.
https://imgur.com/a/64h5F1i
Try configuring a static IP in Linux with the same address as your Windows machine has on the LAN.
If that doesn't work, try adding a virtual switch thru the Hyper-V manager and using that to let the Linux machine have an address thru DHCP. (Assign it to the guest machine)
