We need to install Nagios XI on RHEL8 which is offline, trying to find the correct tarball file from the repo however seems like all the files are for el7. Is there a version for download for el8 available please? If so, can you please provide the link to download.
Thank you.
Offline installation on RHEL8, tarballs no longer available?
Re: Offline installation on RHEL8, tarballs no longer availa
We do not have an ETA on this at this time. Development is aware that customers would like to have that but there is a lot involved in this and they haven't yet said they intend to provide a completely offline package containing all the packages you may need.
The recommended method for offline systems would be to setup internal yum repositories (such as with Redhat Satellite) that it does have access to (or by mounting them up locally to the system so it has access to them):
https://access.redhat.com/solutions/23016
