NAGIOS INSTALLATION ON LINUX RHEL 7.4 (Maipo)
AdanCarbajal
Post by AdanCarbajal »
Can you help me please.
I downloaded this tarball xi-5.8.3.tar
Just I need to install Nagios on Standard version for a simple test of monitoring, if this exist.
Because Im trying to install XI, but the error that show is this:
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS, RHEL, Ubuntu LTS, Debian, or Oracle. Do NOT use this on a system
that has been tasked with other purposes or has an existing install of Nagios Core. To create such a clean install you should have selected
only the base package in the OS installer.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-repos'...
Configuring Repos...
redhatenterpriseworkstation7 is not currently supported. Please use one of the following distros:
CentOS, RHEL, Oracle 7 or 8
Ubuntu 16.04, 18.04, or 20.04 LTS
Debian 9 or 10
RESULT=1
INSTALLATION ERROR!
vtrac
Re: NAGIOS INSTALLATION ON LINUX RHEL 7.4 (Maipo)
Post by vtrac »
Hi AdanCarbajal,
We support only RedHatEnterpriseServer.
Have you considered using a CentOS server or downloading our precompiled OVA?
You can download the latest OVA here:
https://www.nagios.com/downloads/nagios-xi/vmware/
Regards,
Vinh
