Which version of MariaDB is supported by NagiosXI ?
[!!] Your MySQL version 5.5.68-MariaDB is EOL software! Upgrade soon!
Thx!
Supported version of Mariadb
Re: Supported version of Mariadb
Any version of MariaDB is supported. Some of our customers have upgraded to the latest (10 I think) of MariaDB using their official repos, and it seems to be working fine for them.
