Performance Graph showing "No Data to display."
Stuart.Crossan
Post by Stuart.Crossan »
I have a service that has been in a warning state for a few weeks. I recently checked and was able to see data in the performance graph tab for this service. Now when I look at the performance graph I get the message "No data to display". Other services for this host are displaying performance graph data correctly.
What could have stopped this service producing graph data?
vtrac
Re: Performance Graph showing "No Data to display."
Post by vtrac »
Hi Stuart,
Please follow the KB article below to fix the issue:
https://support.nagios.com/kb/article.php?id=9
What is the output of the following command:
lscpu
The "load_threshold = 10.0" is for single CPU.
You should double it with a dual core "load_threshold = 20", with quad core you should use "load_threshold = 40"
You should restart npcd for the changes to take effect:
systemctl restart npcd.service
Also, don't forget to increate the timeout in "/usr/local/nagios/etc/pnp/process_perfdata.cfg":
timeout = 40
Please check the database log (below) and see if the database crashed:
/var/log/mariadb/mariadb.log
If so, please run the below script to fix the database:
/usr/local/nagiosxi/scripts/repair_databases.sh
You can delete everything from: /var/lib/mrtg/ Those are all temp files.
If the above steps do not resolve the issue, please upload the "profile.zip".
Best Regards,
Vinh
