Since I have updated my nagios, I have been having performance problems, especially when applying changes to the system (hosts, services are added etc)
I have already done what is indicated in the documentation but I do not have good results.
Reading another forum, they talk about deleting historical data from the database, checking I see that I have 2 large tables and I wanted to know how deleting that information affects me.
| nagios_logentries | 626.89 |
| nagios_statehistory | 475.93 |
As seen in the images, I don't know what parameter I should change there, and what impact it has on my reports.
I hope you can explain.
I have activated "slow querys" in my mysql server and this query is repeated
# Time: 2021-04-13T11:01:13.187011Z
# User@Host: root[root] @ localhost [] Id: 829132
# Query_time: 64.416918 Lock_time: 0.000000 Rows_sent: 1378547 Rows_examined: 1378547
SET timestamp=1618311608;
SELECT /*!40001 SQL_NO_CACHE */ * FROM `nagios_logentries`;
# Time: 2021-04-13T11:02:08.543221Z
# Query_time: 51.476014 Lock_time: 0.000000 Rows_sent: 1802781 Rows_examined: 1802781
SET timestamp=1618311677;
SELECT /*!40001 SQL_NO_CACHE */ * FROM `nagios_statehistory`;
# Time: 2021-04-13T13:48:36.432417Z
# User@Host: ndoutils[ndoutils] @ localhost [] Id: 837049
# Query_time: 5.249428 Lock_time: 0.001926 Rows_sent: 0 Rows_examined: 0
SET timestamp=1618321711;
# administrator command: Prepare;
# Time: 2021-04-13T15:15:46.841808Z
# User@Host: ndoutils[ndoutils] @ localhost [] Id: 841289
# Query_time: 68.096724 Lock_time: 0.000000 Rows_sent: 1383560 Rows_examined: 1383560
SET timestamp=1618326878;
# Time: 2021-04-13T15:16:54.029660Z
# Query_time: 63.291270 Lock_time: 0.000000 Rows_sent: 1803324 Rows_examined: 1803324
SET timestamp=1618326950;
/usr/libexec/mysqld, Version: 8.0.21 (Source distribution). started with:
Tcp port: 3306 Unix socket: /var/lib/mysql/mysql.sock
Time Id Command Argument
I have changed the server resources increasing the ram from 6 to 16 GB and cpu from 4 to 8 and now to 16. I did this to see if it was lack of resources, but no positive changes are seen.
Excessive CPU usage with MySQL.
benjaminsmith
Re: Excessive CPU usage with MySQL.
The statement:
SELECT /*!40001 SQL_NO_CACHE */ * FROM 'some table';
is used by mysqldump.
Looking at the timestamps I see:
1618311608 Tue Apr 13 2021 11:00:08 GMT+0000
1618311677 Tue Apr 13 2021 11:01:17 GMT+0000
1618321711 Tue Apr 13 2021 13:48:31 GMT+0000
1618326878 Tue Apr 13 2021 15:14:38 GMT+0000
1618326950 Tue Apr 13 2021 15:15:50 GMT+0000
That data (throwing out the timestamp of 13:48) and the SQL statement seem to imply that you are
running backups every four hours. Is that the intention? If not, please check the backup schedule.
Also, please send a System Profile and we'll review the logs for any errors.
Thank you
The statement:
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share this a private message and then reply to this post to bring it up in the queueThank you
Hello, thanks for your help, the strange thing is that accessing Scheduled Backups only makes a daily backup. Where can there be another configuration that is doing backups every 4 hours?
Take a look at the crontabs for all the users and see if they are calling a backup
script. You can look at /var/spool/cron and in /etc/cron.d to see which users have crontabs.
Also, if you know when they are going to run you could run the "top" command
and try to figure it out that way.
