ncpa.db install location
Hi all! Is there currently a way to specify the install/current location of the ncpa.db on the Linux agent side?
Griffin Wakem
Griffin Wakem
benjaminsmith
Re: ncpa.db install location
There isn't an option to specify a different path in the main configuration file (ncpa.cfg), the path is hard coded in the database.py script. A couple of options:
1. Submit an enhancement request on th GitHub site for NCPA
https://github.com/NagiosEnterprises/ncpa
2. Try modifying the path in the source code, and build it on your system.
https://github.com/NagiosEnterprises/nc ... g-on-linux
Also, just curious, what are the requirements for moving the file?
Let us know if you have any questions or need further assistance.
Benjamin
Benjamin
This question stemmed from an inquiry from one of my engineers after the ncpa.db ballooned to 2.1GB, even with the default 30 day retention. I did adjust it to 7 days, but the engineer in question is passionate about where specific items are placed in accordance with LSB. The change of retention should keep this off his radar and in effect keep him happy, so thank you for the information. This can be locked.
Griffin Wakem
Griffin Wakem
Locking threadgwakem wrote:This question stemmed from an inquiry from one of my engineers after the ncpa.db ballooned to 2.1GB, even with the default 30 day retention. I did adjust it to 7 days, but the engineer in question is passionate about where specific items are placed in accordance with LSB. The change of retention should keep this off his radar and in effect keep him happy, so thank you for the information. This can be locked.
