I have to say that I have not found much valid information.
I would like to implement my own menu inside the nagiosxi through the custom includes.
I found a sample but it works halfway and I can't solve the problem.
https://pastebin.com/k5KJAu14
How do I create a custom identical menu, which closes and opens drop-down?
Regards,
-Federico
Custom include
Support_Talea
Custom include
Re: Custom include
I was able to get it to work like this:
$(document).ready(function () {
$("#leftnav").append(
'<div class="menusection">' +
'<div id="mid-menu-home-section-custom" class="menusectiontitle mid-menu-home-section-custom" data-id="menu-home-section-custom">' +
'<i class="fa fa-chevron-down" title="Collapse menu section"></i> Custom Section</div>' +
'<ul class="menusection">' +
'<li class="menulink">' +
'<a href="http://www.bing.com" target="_new">Bing</a>' +
'</li>' +
'<a href="http://www.google.com" target="_new">Google</a>' +
'</li>' +
'<a href="http://www.yahoo.com" target="_new">Yahoo</a>' +
'</li>' +
'</ul>' +
'</div>'
$(".mid-menu-home-section-custom").click(function(e) {
// Verify that we aren't clicking a link
var target = $(e.target);
if (target.is('a')) { return; }
var menusection = $(this).parents('.menusection');
if (menusection.hasClass("menusection-collapsed")) {
menusection.removeClass("menusection-collapsed");
menusection.find('.fa.fa-chevron-up').removeClass('fa-chevron-up').addClass('fa-chevron-down').attr('title', '');
var optsarr = {
"keyname": "menu_collapse_options",
"menuid": $(this).data('id'),
"keyvalue": 1,
"autoload": false
var opts = JSON.stringify(optsarr);
get_ajax_data('setusermeta', opts);
} else {
menusection.addClass("menusection-collapsed");
menusection.find('.fa.fa-chevron-down').removeClass('fa-chevron-down').addClass('fa-chevron-up').attr('title', '');
var optsarr = {
"keyvalue": 0,
"autoload": false
Support_Talea
Re: Custom include
great! it works great.
Good work and many greetings.
Regards,
-Federico
Regards,
-Federico
Re: Custom include
Locking threadSupport_Talea wrote:Hi,
Regards,
-Federico
