Seem to be running into an error on last step on config wiz for Windows Server using NCPA. Tokens and all that work fine and it pulls values and services from the server during setup but gets to the end and is unable to save it off. I looked in the logs and see this info and so checked that import folder and see nothing at all in there. Folder owner is Apache and has same perms as surrounding folders. Not sure where else to look for clues. ???
2021-04-16 13:28:49 Subsystem INFO system localhost Submitted COMMAND_BPI_SYNC (ID=1150) to cmdsubsys
2021-04-16 13:28:11 Core Config Manager MODIFY system localhost File imported - File [overwrite flag]: /usr/local/nagios/etc/import/cNRcCQRU.tmp.cfg [1]
2021-04-16 13:28:10 Core Config Manager MODIFY system localhost File imported - File [overwrite flag]: /usr/local/nagios/etc/import/somerandomserver.local.com.cfg [1]
2021-04-16 13:28:06 User Interface INFO username 10.10.10.10 Submitted COMMAND_NAGIOSCORE_APPLYCONFIG (ID=17) to cmdsubsys
2021-04-16 13:25:46 User Interface SECURITY username 10.20.10.10 Logged in
Unable to finish Config Wiz for Windows Server
Re: Unable to finish Config Wiz for Windows Server
This is to be expected; the "import" folder is a temporary folder it creates during the course of updating your configuration database. It shouldn't be saved.daviddief wrote:I looked in the logs and see this info and so checked that import folder and see nothing at all in there.
What makes you think it's unable to save the configuration? Did it give any error messages?daviddief wrote:but gets to the end and is unable to save it off.
If you PM me a system profile I can diagnose further. Get one by going to Admin (top menu) => System Profile (in the left menu), then clicking the blue button.
If you're unable to generate the the profile through the web interface, please try generating it from the command line by running these commands as root:
rm -rf /usr/local/nagiosxi/var/components/profile*
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORTIf the profile script fails, please include the ENTIRE output.
Hey,
Looks like things are okay now after running the repair_databases script and then performing the delete/write/verify steps. Probably just had not done that in a while so running just fine now. Any guidance on running the steps above as a preventive measure quarterly or just leave it alone?
You could convert the crashed tables to InnoDB.
InnoDB supports ACID compliance, as well as more modern (unused in Nagios) DMBS features such as transactions and foreign keys. The only drawback is it tends to be slower than the MyISAM table type.
If you keep having problems with crashed tables, I'd recommend this option.
The syntax to do this is:
alter table <table name> engine = InnoDB;If you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
