I cannot add more hosts to XI. It looked fine before the update to 5.8.3. When I try to add Windows host with NCPA and save config I get:
Backend login to the Core Config Manager failed.
Please help
5.8.3 Backend login to the Core Config Manager failed.
mario.belamaric
mario.belamaric
Re: 5.8.3 Backend login to the Core Config Manager failed.
Hi again,
I have resolved this by running the repair DB command.
/usr/local/nagiosxi/scripts/repair_databases.sh
Best regards
Best regards
benjaminsmith
Hi @mario.belamaric,
Great. Thanks for the update and for posting your solution.
We'll go ahead and close this out.
