Hi Team,
We are getting below error while taking backup of Nagios XI manually. Could you please help us how we can to get this resolved.
Error backing up MySQL database 'nagios' - check the password in this script!
NagiosXI Backup on 10.144.223.155:
[root@eu1papu002 nagiosxi]# /usr/local/nagiosxi/scripts/backup_xi.sh
\nStarting new backup....\n
Backing up Nagios Core...
tar: Removing leading `/' from member names
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1PAPU084/_log01_usage.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1PAPU084/_HOST_.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1PAPU084: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1RFSW018/_HOST_.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1RFSW018: file changed as we read it
tar: /usr/local/nagios/share/perfdata/C08AAPW160/Committed_Bytes_In_Use.xml: file changed as we read it
tar: /usr/local/nagios/share/perfdata/C08AAPW160: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1RAPW076/_HOST_.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/EU1RAPW076: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
tar: /var/lib/mrtg/10.149.250.2_65.rrd: file changed as we read it
tar: /var/lib/mrtg/10.144.249.121_44.rrd: file changed as we read it
tar: /var/lib/mrtg: file changed as we read it
Backing up the SNMP directories
Backing up NRDP...
Backing up Nagvis...
Backing up nagios user home dir...
Backing up MySQL databases...
mysqldump: Got errno 28 on write
You have new mail in /var/spool/mail/root
Nitin Parate
Error while taking NagiosXI Backup
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: Error while taking NagiosXI Backup
What's the output from the following command?
df -hIf you didn't get an 8% raise over the course of the pandemic, you took a pay cut.
[root@eu1papu002 nagiosxi]# df -h /store
/dev/mapper/rootvg-storelv 19G 11G 8.0G 57% /store
devtmpfs 7.8G 0 7.8G 0% /dev
tmpfs 7.8G 0 7.8G 0% /dev/shm
tmpfs 7.8G 778M 7.0G 10% /run
tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/mapper/rootvg-rootlv 9.1G 233M 8.4G 3% /
/dev/mapper/rootvg-usrlv 28G 20G 6.7G 75% /usr
/dev/sda1 9.1G 221M 8.4G 3% /boot
/dev/mapper/rootvg-homelv 14G 88M 14G 1% /home
/dev/mapper/rootvg-tmplv 9.1G 302M 8.3G 4% /tmp
/dev/mapper/rootvg-varlv 110G 4.8G 100G 5% /var
tmpfs 1.6G 0 1.6G 0% /run/user/1001
tmpfs 1.6G 0 1.6G 0% /run/user/2101
You have mail in /var/spool/mail/root
Thanks & Regards,
I2MP Team.
I2MP Team.
Hi
Backup Failed Mysqldump Got Errno 28 On Write
https://sittinginoblivion.com/wiki/back ... o-28-write
Looks like you might want to clean up the "/store" and "/tmp" filesystems, then try the backup again.
Best Regards,
Vinh
Error Message
Backup failed: mysqldump: Got errno 28 on write
Meaning
Insufficient disk space to store output.
Solution
Free up some disk space. You might want to track down the reason you're low on disk space too.
Best Regards,
Vinh
