Problems finalizing Nagios Log Server (2.1.8) install
HIINNS
Post by HIINNS »
All,
I am trying to install Nagios Logserver ver. 2.1.8. I get to the screen shown in the attachment below. Shown below the attachment is a somewhat cryptic message denying me finalizing the install. I have tried for the last day and a half to resolve the problem. I should mention that the install of the product was done in a piecemeal fashion, as I do not have external internet access on any of my Linux servers and had to download the files to my desktop server and deploy them on the server. Please see the attached file and if possible, let me know what I need to do to make this install work. Thank you.
ssax
Dreams In Code
Re: Problems finalizing Nagios Log Server (2.1.8) install
Post by ssax »
Do you have selinux enabled?
sestatus
If so, please disable it as it's not currently supported.
What is the output of this command?
ls -ld /var/www/html/nagioslogserver/application/cache
HIINNS
Post by HIINNS »
The response to ls -ld /var/www/html/nagioslogserver/application/cache is -> drwxrwxr-x. 2 apache apache 19 Apr 16 11:44 /var/www/html/nagioslogserver/application/cache
However, I have tried it with userid and groupid of nagios:nagios and got the same errors.
It appears that the server is using selinux. I will see about getting it turned off. I'll let you know where this stands after getting it turned off (if I can get it turned off).
Thank you for your assistance,
HIINNS
Post by HIINNS »
All,
I there a way to finishing installing the application, then turn selinux back on and having it work?
vtrac
Post by vtrac »
Check the SELinux state:
getenforce
There are two ways that you can disable SELinux - either by editing a config file, or by using the setenforce command
If editing the config file, Open the /etc/selinux/config file (in some systems, the /etc/sysconfig/selinux file).
Change the line SELINUX=enforcing to SELINUX=permissive.
Save and close the file.
Reboot your system
or
If using the setenforce simply run the command
sudo setenforce 0
Enable SELinux:
sudo setenforce 1
To check:
getenforce
Best Regards,
Vinh
HIINNS
Post by HIINNS »
Got it to work. It does work with selinux after it is installed.
HIINNS wrote:Got it to work. It does work with selinux after it is installed.
Great
Locking thread
