have a question:
I am monitoring the ping of several hosts every minute, but when I get a status history report, and seeing that the host has fallen to the hard state and that it has exhausted all attempts, between attempts there is not a minute if not more. I don't know if this is a mistake. I send screenshots
Thank you very much for your time
state time in state repost history does not correspond to th
Re: state time in state repost history does not correspond t
It looks like the re-check interval is 4 minutes and eight seconds. Please check that.
If it is set to something other than that please send a System Profile.
To send us your system profile.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Profile" Menu
3. Click the "Download Profile" button
4. Save the profile.zip file and share this a private message and then reply to this post to bring it up in the queue.
I cannot send you the confidentiality profile of my client, Can you tell the problem without seeing the profile? Thank you
benjaminsmith
In this situation, it would be best to open a support ticket as the information shared is private between the customer and the support team Any current customer can view the conversations on the support forum.
https://support.nagios.com/tickets/
--Benjamin
--Benjamin
My client does not allow me to share nagios information, I will try to provide the profile without hostname, ip's, services, and descriptions, in the ticket
you can close the query thank you very much
Locking threadnmarbue79 wrote:you can close the query thank you very much
