Hi, to mitigate CVE-2021-25296 on this page https://www.nagios.com/products/security/ I can see the following instructions:
Upgrade the Windows WMI config wizard from Admin > Manage Config Wizards to version 2.2.3 or above.
But from that page I have version 2.2.2 with no update available. I'm on NagiosXI 5.7.5.
How can I install the update?
Thank you
Matteo
Windows WMI config wizard 2.2.3 update
Re: Windows WMI config wizard 2.2.3 update
I have attached the "configwizard-windowswmi.zip" v2.2.4 file.
How to install:
Nagios XI GUI > Admin > System Extensions > Manage Configuration Wizards
Click "Browse..."
Select the attached zip file from your download folder
Click "Upload & Install"
Best Regards,
Vinh
How to install:
Click "Browse..."
Best Regards,
Vinh
Thank you!
May I close / lock this thread?
Regards,
Vinh
Regards,
Vinh
