Hi Support, I have two checkpoint 5400, configured as a cluster. I would like to setup a monitoring plugin which can monitor Hardware state/Running state/IPsec VPN tunnel up & down/etc. Do you have some plugin I can try,
Monitor Checkpoint Firewalls
Re: Monitor Checkpoint Firewalls
I searched Nagios Exchange and found couple checkpoint modules that you might want to try out:
https://exchange.nagios.org/index.php?o ... checkpoint
Best Regards,
Vinh
Best Regards,
Vinh
Thanks, actually, i did same. but most of them are too old. My Gaia version is R81. I am trying 'check_nwc_health' now, Hope it can help.
You could also try SNMP.
I found the below URL page which included the MIB file for R81.
You can upload MIB file onto your Nagios XI, then use SNMP WALK wizard to pull it.
https://supportcenter.checkpoint.com/su ... id=sk90470
To upload MIB:
Admin > Manage MIBs
Best Regards,
Vinh
To upload MIB:
Admin > Manage MIBs
Best Regards,
Vinh
