I followed https://assets.nagios.com/downloads/nag ... ios-XI.pdf and got it "working", it sometimes manages to check the values. But most of the time, I just receive a "plugin timeout" error.
I read https://security.stackexchange.com/ques ... tropy-pool, installed havege, which I believe smoothed things a bit : it now succeeds half of time (with lot of vmware checks disabled).
2 questions then :
- Is there a way to make this monitoring work ?
- As the vmware perl sdk is deprecated, is there a move to python sdk, or even directly to the web API ?
Regards,
RHEL 8 - vmware sdk7 - plugin timeout
benjaminsmith
Re: RHEL 8 - vmware sdk7 - plugin timeout
Hi Jmonn,
The intermittent timeout issues are often network-related. Any issues pinging the host?
Let's run a few commands directly from the CLI and try to get some more information back for debugging. Please post the output to the thread.
For VM Host:
For VM Guest:
Regards,
Benjamin
For VM Host:
/usr/local/nagios/libexec/check_vmware_api.pl -H X.X.X.X -uyouruser -p'yourpassword' -l "CPU" -vvvCode: Select all
/usr/local/nagios/libexec/check_vmware_api.pl -H X.X.X.X -uyouruser -p'yourpassword' -N 'yourvmname' -l "CPU" -vvvBenjamin
network is not the issue here, no firewall on the VM, and nagios has been running on this VM for almost 2 years before we tried (and failed) upgrading from rhel 7 to rhel 8. (So I can not test it anymore...)
Second question was about moving to something else for vmware monitoring : vmware recommends moving to python sdk, is there any project on that ? https://kb.vmware.com/s/article/80144
Regards,
Regards,
benjaminsmith
We will likely upgrade this after Nagios XI 6 is released. Right now, I do not have an exact date or timeline.
Regards,
Benjamin
Regards,
Benjamin
