Could not bind socket: Address already in use_ndoutils1.5.2
pypath
Post by pypath »
Seek help.
After installing ndoutils, tips:
[root@localhost ndoutils-1.5.2]# rm -rf /usr/local/nagios/var/ndo2db.lock
[root@localhost ndoutils-1.5.2]# /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
And, not in the database data.
Attempt to
/etc/init.d/nagios stop
/etc/init.d/nagios start
Or above problem, online etc.
jsmurphy
Re: Could not bind socket: Address already in use_ndoutils1.
Post by jsmurphy »
if you do a "ps -ef | grep ndo2db" do you see the ndo2db process running? You will need to kill it first before attempting to restart it.
