I can add auth servers via the API easily enough
But I cant add the certificate
Is there any way to do this programmatically?
Also is there a way of setting other admin area settings - like system settings, email setttings, backups etc
Adding LDAP Certificates automatically
optionstechnology
Re: Adding LDAP Certificates automatically
It's not currently possible to do that through the API. Does your automation tool have the ability to add files/run commands/restart services at the OS level? If so, what OS/version are you running?
uname -a
cat /etc/*release-
optionstechnology
Yeah we can change the config files directly and run commands/restart services
running centos 7.9
running centos 7.9
You should be able to add the entire CA cert chain in individual pem format files into:
Then run:
If that doesn't work you should be able to put your entire CA certificate chain in pem encoded format in a file in:
I'm using /etc/openldap/certs/ca.pem in the example below.
Then run these commands against it:
/etc/pki/ca-trust/source/anchors/Code: Select all
update-ca-trust extract
systemctl restart httpdCode: Select all
/etc/openldap/certsThen run these commands against it:
chown apache.nagios /etc/openldap/certs/ca.pem
echo 'TLS_CACERT /etc/openldap/certs/ca.pem' >> /etc/openldap/ldap.conf
systemctl restart httpd-
optionstechnology
yup this worked perfectly, thanks
for the other settings-
We need to check: Allow HTML Tags in Host/Service Status
uncheck: Sticky Acknowledgement
change the "send from" address in mail settings
For backups check the 'Enable Local Backups' checkbox
Set it to run Daily at 18:00 to /store/backups/nagiosxi
Set a backup limit of 5
are all these things also possible by changing the settings in config files?
Those are not currently modifiable like that because you need to be logged in to do it to pull the other information that is submitted with them.
