NCP Agent not detecting XFS File System
Sampath.Basireddy
Hello There,
Does NCP Agent v2.3.1 support monitoring of XFS File System?
Before upgrading to the latest version of NCP Agent, Disk usage monitoring of XFS FS was working fine, but post upgrade, the FS is not being detected.
When I check in the NCPA Web Console of the respective server, it does show the XFS FS.
Any inputs please?
Any inputs please?
Re: NCP Agent not detecting XFS File System
I just labbed this up and it's showing xfs on NCPA v2.3.1 properly.
Does it show here? (select API > Disk > Logical)
- Change X.X.X.X to the IP of the NCPA host, open it in a web browser
Are you seeing any errors in your ncpa_listener.log on the NCPA host?
https://X.X.X.X:5693/gui/api-
Sampath.Basireddy
Yes, I can see all the disks "xfs" when I access the NCPA Console.
Attaching the web console screenshot for reference.
Great!! .... can we close / lock this thread?
Regards,
Vinh
Regards,
Vinh
Sampath.Basireddy
I can see the FS in NCPA Console, but the issue here is, when I create a Disk Usage Service, it fails on me.
UNKNOWN: The node (/var/lib/ceph/osd/ceph-27) requested does not exist. You may be trying to access the '/' node.Re: NCP Agent not detecting XFS File System
Please upload the command you used, which produced the error in your last reply.
Also, please run the below command and update ALL outputs to this thread so we can work on the issue:
(NOTE: x.x.x.x is the IP address of the remote NCPA machine. You can get the "token / community_string" in the "/usr/local/ncpa/etc/ncpa.cfg" file on your NCPA remote machine)
Best Regards,
Vinh
curl -k 'https://x.x.x.x:5693/api/disk/?token=yourToken'
Vinh
Sampath.Basireddy
Here is the command:
I will pm you the output of curl command.
[root@nagios1 ~]# /usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/logical/|var|lib|ceph|osd|ceph-11/used_percent' -c 90 -w 85
UNKNOWN: The node (/var/lib/ceph/osd/ceph-11) requested does not exist. You may be trying to access the '/' node.Re: NCP Agent not detecting XFS File System
Could you please also update the output of the below "df" command?
I need that to compare with the curl outputs.
Regards,
Vinh
df -hT
Vinh
Sampath.Basireddy
Here is the output of df -hT from one of the issue nodes:
root@server009:~# df -hT
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 126G 0 126G 0% /dev
tmpfs tmpfs 26G 50M 26G 1% /run
/dev/mapper/ceph09--vg-root ext4 218G 4.8G 202G 3% /
tmpfs tmpfs 126G 12K 126G 1% /dev/shm
tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs tmpfs 126G 0 126G 0% /sys/fs/cgroup
/dev/sdy2 ext2 721M 141M 544M 21% /boot
/dev/sdy1 vfat 511M 3.7M 508M 1% /boot/efi
/dev/sdx1 xfs 1.1T 577G 541G 52% /var/lib/ceph/osd/ceph-179
/dev/sdn1 xfs 1.1T 522G 596G 47% /var/lib/ceph/osd/ceph-169
/dev/sdi1 xfs 1.1T 695G 422G 63% /var/lib/ceph/osd/ceph-164
/dev/sdv1 xfs 1.1T 499G 619G 45% /var/lib/ceph/osd/ceph-177
/dev/sdm1 xfs 1.1T 499G 619G 45% /var/lib/ceph/osd/ceph-168
/dev/sdk1 xfs 1.1T 609G 509G 55% /var/lib/ceph/osd/ceph-166
/dev/sdq1 xfs 1.1T 693G 425G 62% /var/lib/ceph/osd/ceph-172
/dev/sdt1 xfs 1.1T 531G 586G 48% /var/lib/ceph/osd/ceph-175
/dev/sdh1 xfs 1.1T 613G 504G 55% /var/lib/ceph/osd/ceph-163
/dev/sdo1 xfs 1.1T 560G 558G 51% /var/lib/ceph/osd/ceph-170
/dev/sdg1 xfs 1.1T 456G 662G 41% /var/lib/ceph/osd/ceph-162
/dev/sdl1 xfs 1.1T 711G 407G 64% /var/lib/ceph/osd/ceph-167
/dev/sdj1 xfs 1.1T 510G 607G 46% /var/lib/ceph/osd/ceph-165
/dev/sdu1 xfs 1.1T 553G 565G 50% /var/lib/ceph/osd/ceph-176
/dev/sdf1 xfs 1.1T 419G 699G 38% /var/lib/ceph/osd/ceph-161
/dev/sde1 xfs 1.1T 582G 536G 53% /var/lib/ceph/osd/ceph-160
/dev/sdp1 xfs 1.1T 525G 593G 47% /var/lib/ceph/osd/ceph-171
/dev/sdr1 xfs 1.1T 666G 452G 60% /var/lib/ceph/osd/ceph-173
/dev/sdw1 xfs 1.1T 556G 562G 50% /var/lib/ceph/osd/ceph-178
/dev/sds1 xfs 1.1T 594G 524G 54% /var/lib/ceph/osd/ceph-174
tmpfs tmpfs 26G 0 26G 0% /run/user/1002
root@server009:~#Re: NCP Agent not detecting XFS File System
Based on the outputs of "curl", we have the following tree structure (example):
Here are some example of "check_ncpa.py".
If I want to find "/boot", I would follow the tree down ....
"disk/logical/|boot/used_percent"
or
"disk/logical/|boot/inodes_used" ..... you get the idea here ....
Based on the structure of "curl" output, I can contruct the "check_ncpa.py" .... please see example below:
If you want "use_percent' of "/boot" filesystem, your command must be like this:
"free" on "/boot":
"free" on "/" filesystsem:
"read_bytes" of "sdf3":
List "device_name" of "|var|lib|ceph|osd|ceph-63":
List "fstype" of "|var|lib|ceph|osd|ceph-63":
As you can see, the "curl" output is very useful. You used that to setup your "check_ncpa.py" call with the "-M" option.
Best Regards,
Vinh
"disk": {
"mount": {
"|var|lib|ceph|osd|ceph-63": {
"fstype":
"opts":
"device_name":
"logical": {
"|boot": {
"used_percent":
"used":
"inodes_used":
"free":
"device_name":
"inodes_free":
"inodes":
"fstype":
"total":
"opts":
"inodes_used_percent":
"physical": {
"sdf3": {
"read_time":
"read_bytes":
"write_count":
"write_time":
"write_bytes":
"read_count":
or
disk:
"logical": {
"|boot": {
"used_percent":
"used":
"inodes_used":
"free":
"device_name":
"inodes_free":
"inodes":
"fstype":
"total":
"opts":
},If you want "use_percent' of "/boot" filesystem, your command must be like this:
/usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/logical/|boot/used_percent'Code: Select all
/usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/logical/|boot/free'Code: Select all
/usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/logical/|/free'Code: Select all
/usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/physical/sdf3/read_bytes'Code: Select all
/usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/mount/|var|lib|ceph|osd|ceph-63/device_name'Code: Select all
/usr/local/nagios/libexec/check_ncpa.py -H xx.xx.xx.xxx -t <tokenID> -P 5693 -M 'disk/mount/|var|lib|ceph|osd|ceph-63/fstype'Best Regards,
Vinh
