I would like to know is there any way to build a map with host and services (deducing by monitored services) with Nagios XI ?
I found the "network map" but there is so host displayed and there are displayed like they was all on the same network. How I can tell to Nagios XI which host are connected to that firewall etc ? Can I custom this view to add services ?
Thank's
Using Nagios data to build Map of hosts and services
Re: Using Nagios data to build Map of hosts and services
You can build a logical network map by setting parent hosts for each of your monitored network devices. For instance, you'd want to add a host for your firewall, then for each host you want "under" that firewall, you'd set the parent host to the firewall.
See: https://support.nagios.com/kb/article/n ... s-505.html
See also: Introduction to Nagios XI Webinar: https://youtu.be/Q-4bnVeCJOQ
- Explains adding hosts to topology diagrams at 44:44
Thank you for your response.
Can I add services in this map too ?
There is a third-party tool called NagVis that is already on XI and you just have to configure its capabilities.
It maps out your parent/child relations of hosts and services that are configured with Nagios XI. Here is the documentation on it.
Also, check our more Addons for Maps on Nagios Exchange.
https://exchange.nagios.org/directory/A ... d-Diagrams
