Is there any possibility that the nagios will corrupt the passive check result line?
As explained at https://assets.nagios.com/downloads/nag ... hecks.html, the format should be
[<timestamp>] PROCESS_SERVICE_CHECK_RESULT;...Code: Select all
3] PROCESS_SERVICE_CHECK_RESULT;...I don't think the external application writes such broken text to nagios.cmd since parsing it will fail before nagios triggers alerts. I wonder who broke the timestamp part inside Nagios.
Thanks.
