nagios_servicechecks inserts failed - XI 5.8.2
level2_prod_support
MYSQL insert query failed messages are showing on nagios.log. Could you please guide, how to resolve this issue.
Version: Nagios XI 5.8.3
[1620649194] NDO-3: INSERT INTO nagios_servicechecks (instance_id, start_time, start_time_usec, end_time, end_time_usec, service_object_id, check_type, current_check_attempt, max_check_attempts, state, state_type, timeout, early_timeout, execution_time, latency, return_code, output, long_output, perfdata, command_object_id, command_args, command_line) VALUES (1,FROM_UNIXTIME(1620649194),921580,FROM_UNIXTIME(1620649194),927575,1026,0,1,1,0,1,60,0,0.005995,0.000928,0,'D:\\ - total: 20.00 Gb - used: 2.19 Gb (11%) - free 17.81 Gb (89%)','','\'D:\\ Used Space\'=2.19Gb;16.00;19.00;0.00;20.00',0,'','') ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), start_time = VALUES(start_time), start_time_usec = VALUES(start_time_usec), end_time = VALUES(end_time), end_time_usec = VALUES(end_time_usec), service_object_id = VALUES(service_object_id), check_type = VALUES(check_type), current_check_attempt = VALUES(current_check_attempt), max_check_attempts = VALUES(max_check_attempts), state = VALUES(state), state_type = VALUES(state_type), timeout = VALUES(timeout), early_timeout = VALUES(early_timeout), execution_time = VALUES(execution_time), latency = VALUES(latency), return_code = VALUES(return_code), output = VALUES(output), long_output = VALUES(long_output), perfdata = VALUES(perfdata), command_object_id = VALUES(command_object_id), command_args = VALUES(command_args), command_line = VALUES(command_line)
[1620649195] NDO-3: The following query failed while MySQL appears to be connected:
Re: nagios_servicechecks inserts failed - XI 5.8.2
Hi there,
Could you please get me a System Profile?
To send us your system profile.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Profile" Menu
3. Click the "Download Profile" button
4. Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
Additionally on a CLI of the server please run:
mysqlcheck -u root -p nagios
( default password is nagiosxi)
Let me know if anything comes back without an "OK" result.
level2_prod_support
-bash-4.2$ mysqlcheck -u root -p nagios
Enter password:
nagios.nagios_acknowledgements OK
nagios.nagios_commands OK
nagios.nagios_commenthistory OK
nagios.nagios_comments OK
nagios.nagios_configfiles OK
nagios.nagios_configfilevariables OK
nagios.nagios_conninfo OK
nagios.nagios_contact_addresses OK
nagios.nagios_contact_notificationcommands OK
nagios.nagios_contactgroup_members OK
nagios.nagios_contactgroups OK
nagios.nagios_contactnotificationmethods OK
nagios.nagios_contactnotifications OK
nagios.nagios_contacts OK
nagios.nagios_contactstatus OK
nagios.nagios_customvariables OK
nagios.nagios_customvariablestatus OK
nagios.nagios_dbversion OK
nagios.nagios_downtimehistory OK
nagios.nagios_eventhandlers OK
nagios.nagios_externalcommands OK
nagios.nagios_flappinghistory OK
nagios.nagios_host_contactgroups OK
nagios.nagios_host_contacts OK
nagios.nagios_host_parenthosts OK
nagios.nagios_hostchecks OK
nagios.nagios_hostdependencies OK
nagios.nagios_hostescalation_contactgroups OK
nagios.nagios_hostescalation_contacts OK
nagios.nagios_hostescalations OK
nagios.nagios_hostgroup_members OK
nagios.nagios_hostgroups OK
nagios.nagios_hosts OK
nagios.nagios_hoststatus OK
nagios.nagios_instances OK
nagios.nagios_logentries OK
nagios.nagios_notifications OK
nagios.nagios_objects OK
nagios.nagios_processevents OK
nagios.nagios_programstatus OK
nagios.nagios_runtimevariables OK
nagios.nagios_scheduleddowntime OK
nagios.nagios_service_contactgroups OK
nagios.nagios_service_contacts OK
nagios.nagios_service_parentservices OK
nagios.nagios_servicechecks OK
nagios.nagios_servicedependencies OK
nagios.nagios_serviceescalation_contactgroups OK
nagios.nagios_serviceescalation_contacts OK
nagios.nagios_serviceescalations OK
nagios.nagios_servicegroup_members OK
nagios.nagios_servicegroups OK
nagios.nagios_services OK
nagios.nagios_servicestatus OK
nagios.nagios_statehistory OK
nagios.nagios_systemcommands OK
nagios.nagios_timedeventqueue OK
nagios.nagios_timedevents OK
nagios.nagios_timeperiod_timeranges OK
nagios.nagios_timeperiods OK
Enter password:
Hi
Your database was having problems because your disk is full:
Take care of that and let me know if the insert problem is solved.
210313 8:36:35 [Note] Retrying repair of: './nagios/nagios_statehistory' including modifying data file
210315 12:40:05 [Warning] IP address '172.30.12.134' could not be resolved: Name or service not known
210319 1:10:15 [Warning] mysqld: Disk is full writing './nagios/nagios_logentries.TMD' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210319 1:10:15 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210326 1:10:31 [Warning] mysqld: Disk is full writing '/var/lib/mysql/nagios/nagios_logentries.MYI' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210326 1:10:31 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210327 1:09:50 [Warning] mysqld: Disk is full writing './nagios/nagios_eventhandlers.MYD' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210327 1:09:50 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210329 1:08:35 [Warning] mysqld: Disk is full writing '/var/lib/mysql/nagios/nagios_logentries.MYI' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210329 1:08:35 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210330 1:08:53 [Warning] mysqld: Disk is full writing '/var/lib/mysql/nagios/nagios_logentries.MYI' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210330 1:08:53 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210330 9:46:04 [Warning] IP address '172.30.10.2' could not be resolved: Name or service not known
210401 1:08:23 [Warning] mysqld: Disk is full writing '/var/lib/mysql/nagios/nagios_contactnotificationmethods.MYI' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210401 1:08:23 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210402 1:07:58 [Warning] mysqld: Disk is full writing './nagios/nagios_statehistory.MYD' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210402 1:07:58 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210403 1:08:43 [Warning] mysqld: Disk is full writing '/var/lib/mysql/nagios/nagios_logentries.MYI' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210403 1:08:43 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210404 1:08:52 [Warning] mysqld: Disk is full writing './nagios/nagios_eventhandlers.MYD' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
210404 1:08:52 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
210405 1:08:26 [Warning] mysqld: Disk is full writing '/var/lib/mysql/nagios/nagios_logentries.MYI' (Errcode: 28). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disThanks
level2_prod_support
/var has enough space. I don't see disk full on the box. Could you please guide which one to clear.
-bash-4.2$ df -h /var
/dev/mapper/rootvg-varvol 16G 9.6G 4.9G 67% /var
-bash-4.2$
-bash-4.2$ df -h
devtmpfs 32G 0 32G 0% /dev
tmpfs 32G 0 32G 0% /dev/shm
tmpfs 32G 98M 32G 1% /run
tmpfs 32G 0 32G 0% /sys/fs/cgroup
/dev/mapper/rootvg-rootvol 16G 4.2G 11G 29% /
/dev/sda1 969M 113M 791M 13% /boot
/dev/mapper/storevg-store 70G 5.7G 65G 9% /store
/dev/mapper/userlocalvg-usrlocal 50G 19G 32G 38% /usr/local
/dev/mapper/appsvg-apps 25G 40M 25G 1% /apps
tmpfs 6.3G 0 6.3G 0% /run/user/45128
| table_schema | MB |
| information_schema | 0.15625000 |
| mysql | 2.52234554 |
| nagios | 395.44248578 |
| nagiosql | 3.50000000 |
| nagiosxi | 53.00000000 |
| performance_schema | 0.00000000 |
| sys | 0.01562500 |
7 rows in set (0.06 sec)
-bash-4.2$
-bash-4.2$ df -h
| table_schema | MB |
| sys | 0.01562500 |
Hi
The logs were showing /var as being full, but somehow that was mitigated. Please take another
System Profile and send it to me. Thanks
level2_prod_support
Sent profile file as PM. please review
Hi
The profile was not attached. Please resend.
level2_prod_support
Sent profile file again as PM. please review
hi,
Looks good. Please run the insert command manually and let me know the output.
So it would be something like:
Let me know if it works or not.
If you get an error running the above insert statement then save the error message for me and then I want you to
downgrade the NDO-3 broker to ndoutils by following these steps:
systemctl stop nagios
cd /tmp
rm -rf /tmp/nagiosxi
wget https://assets.nagios.com/downloads/nag ... .14.tar.gz
tar zxf xi-5.6.14.tar.gz
cd /tmp/nagiosxi
./init.sh
cd /tmp/nagiosxi/subcomponents/ndoutils
./installsystemctl enable ndo2db
systemctl start ndo2db
Then edit your /usr/local/nagios/etc/nagios.cfg and make sure this line is not commented out or if it is not there add it:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Search for the line below and comment it out by adding a # at the beginning of the line:
#broker_module=/usr/local/nagios/bin/ndo.so /usr/local/nagios/etc/ndo.cfg
Then start the nagios service: systemctl start nagios
Now try running the sql insert statement again.
Let me know all the results please.
mysql -u root -p nagios
<enter password>
INSERT INTO nagios_servicechecks (instance_id, start_time, start_time_usec, end_time, end_time_usec, service_object_id, check_type, current_check_attempt, max_check_attempts, state, state_type, timeout, early_timeout, execution_time, latency, return_code, output, long_output, perfdata, command_object_id, command_args, command_line) VALUES (1,FROM_UNIXTIME(1620844440),0,FROM_UNIXTIME(0),0,2028,1,1,1,0,1,60,1,0.000000,0.000000,0,'Process UP=6','','',0,'','') ON DUPLICATE KEY UPDATE instance_id = VALUES(instance_id), start_time = VALUES(start_time), start_time_usec = VALUES(start_time_usec), end_time = VALUES(end_time), end_time_usec = VALUES(end_time_usec), service_object_id = VALUES(service_object_id), check_type = VALUES(check_type), current_check_attempt = VALUES(current_check_attempt), max_check_attempts = VALUES(max_check_attempts), state = VALUES(state), state_type = VALUES(state_type), timeout = VALUES(timeout), early_timeout = VALUES(early_timeout), execution_time = VALUES(execution_time), latency = VALUES(latency), return_code = VALUES(return_code), output = VALUES(output), long_output = VALUES(long_output), perfdata = VALUES(perfdata), command_object_id = VALUES(command_object_id), command_args = VALUES(command_args), command_line = VALUES(command_line)
cd /tmp
cd /tmp/nagiosxi
./init.sh
