Windows Apllication error log checker
btayl
Post by btayl »
What Plugin should I use that checks the last entrys in a log file for a match and this is in windows or it could be done on a smb file check if thier is one that would do that.
ssax
Dreams In Code
Re: Windows Apllication error log checker
Post by ssax »
Do you have an agent installed on the system currently?
NCPA can monitor the event logs:
https://www.nagios.org/ncpa/help.php#api-modules-logs
As well as NSClient++:
https://docs.nsclient.org/reference/win ... kEventLog/
