api to add comment
api to add comment
Am I blind or is there no endpoint to add a comment? I want our ticketing system to add a comment of the ticket # when it gets an alert from Nagios.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
benjaminsmith
Re: api to add comment
Hi Bandit,
The way to do that would be to use POST system/corecommand endpoint to send a Core command that will add a comment.
For example:
Let me know if that works for you.
Benjamin
For example:
curl -XPOST "https://192.168.23.113/nagiosxi/api/v1/system/corecommand?apikey=sCWXTQ3rHtm483AgRUUtLi04v5ECCVmktCCGoU8mINpPPflWafJbRKeGO8fGjUh6" -d "cmd=ADD_HOST_COMMENT;localhost;1;%user%;This is a test comment"
Benjamin
This will work, but what permissions are needed? I had a read only user that it wouldn't work even though they had API access. I then changed to this and still get Authentication failed
I tried it with my admin user's api key and it works great.
Currently regular users only have access to the objects API endpoint, they would need to be an admin to use the other endpoints (system/config/etc).
