SNMP CRITICAL - *up(1)*
silentnoise
Post by silentnoise »
i`m new in nagios.
I`m trying to monitor my Home-Network.
In this case i am trying to monitor the upstates of my 8-Port-Switch by 3Com.
In Port 1,7 and 8 is inserted an Cable.
Port 1 is the Uplink
On Port 7 and 8 i?ve plugged 2 Devices.
Only the port 1 is ok.
The rest gives the State "CRITICAL"
Port 1 Link Status
	OK 	05-12-2021 16:36:18 	3d 18h 31m 3s 	1/3 	SNMP OK - up(1)
Port 2 Link Status
	CRITICAL 	05-12-2021 16:33:02 	0d 2h 56m 39s 	3/3 	SNMP CRITICAL - *up(1)*
Port 3 Link Status
	CRITICAL 	05-12-2021 16:35:30 	3d 16h 56m 25s 	3/3 	SNMP CRITICAL - *up(1)*
Port 4 Link Status
	CRITICAL 	05-12-2021 16:36:59 	3d 16h 52m 58s 	3/3 	SNMP CRITICAL - *up(1)*
Port 5 Link Status
	CRITICAL 	05-12-2021 16:35:51 	3d 16h 50m 8s 	3/3 	SNMP CRITICAL - *up(1)*
Port 6 Link Status
	CRITICAL 	05-12-2021 16:37:16 	3d 16h 47m 33s 	3/3 	SNMP CRITICAL - *up(1)*
Port 7 Link Status
	CRITICAL 	05-12-2021 16:37:42 	3d 16h 45m 58s 	3/3 	SNMP CRITICAL - *up(1)*
Port 8 Link Status
	CRITICAL 	05-12-2021 16:34:29 	3d 16h 44m 42s 	3/3 	SNMP CRITICAL - *up(1)*
My Configfile:
define host {
use generic-switch ; Inherit default values from a template
host_name 3-Com-Switch ; The name we're giving to this switch
alias 3-Com-Switch ; A longer name associated with the switch
address 192.168.178.3 ; IP address of the switch
hostgroups switches ; Host groups this switch is associated with
define hostgroup {
hostgroup_name switches ; The name of the hostgroup
alias Network Switches ; Long name of the group
use generic-service ; Inherit values from a template
host_name 3-Com-Switch ; The name of the host the service is associated with
service_description PING ; The service description
check_command check_ping!200.0,20%!600.0,60% ; The command used to monitor the service
check_interval 5 ; Check the service every 5 minutes under normal conditions
retry_interval 1 ; Re-check the service every minute until its final/hard state is determined
# Monitor uptime via SNMP
service_description Uptime
check_command check_snmp!-C public -o sysUpTime.0
# Monitor Port 1 status via SNMP
service_description Port 1 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 1 -m RFC1213-MIB
service_description Port 2 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 2 -m RFC1213-MIB
service_description Port 3 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 3 -m RFC1213-MIB
service_description Port 4 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 4 -m RFC1213-MIB
service_description Port 5 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 5 -m RFC1213-MIB
service_description Port 6 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 6 -m RFC1213-MIB
service_description Port 7 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 7 -m RFC1213-MIB
service_description Port 8 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 8 -m RFC1213-MIB
Can anybody help me, to find the failure?
Why is the state critical ?
Greets :)
rhassing
Re: SNMP CRITICAL - *up(1)*
Post by rhassing »
You have an error in the service config:
For interface 1 use:
For interface 2 use:
check_command check_snmp!-C public -o ifOperStatus.[b]2[/b] -r [b]1[/b] -m RFC1213-MIB
The -r should always have 1 (or up)
The number behind ifOperStatus is the interface number, the -r option is what is expected from the output (in regex)
Rob Hassing
silentnoise
thanks for reply.
Are you sure ?
I changed into:
        use                                 generic-service
        check_command              check_snmp!-C public ifOperStatus.2 -r 1 -m RFC1213-MIB
It says:
3-Com-Switch
Port 2 Link Status
	UNKNOWN 	05-13-2021 19:13:21 	0d 0h 5m 47s 	3/3 	External command error: Error in packet
Service Unknown[05-13-2021 19:13:21] SERVICE ALERT: 3-Com-Switch;Port 2 Link Status;UNKNOWN;HARD;3;External command error: Error in packet
rhassing
Post by rhassing »
Your command is nog correct anymote. I think it's missing the -o
        use                                 generic-service
Should be
        use                                 generic-service
        check_command              check_snmp!-C public -o ifOperStatus.2 -r 1 -m RFC1213-MIB
Rob Hassing
silentnoise
i`m sorry i forgot the "-o".
I write it manually into the post.
This is the ertry in the file...
rhassing
Post by rhassing »
What do you see if you execute the command in the command line?
Can you post that? Command and output.
Rob Hassing
silentnoise
But it doesn't work
silentnoise
root@raspberrypi:/usr/local/nagios/libexec# ./check_snmp -H 192.168.178.3 public -o ifOperStatus.2 -r 1 -m RFC1213-MIB
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: RFC1213-MIB::ifOperStatus.2
silentnoise
I`ve done a SNMPwalk.
Is it possible that the other ports cannot be read out?
snmpwalk.txt
SNMPwalk
(34.41 KiB) Downloaded 1118 times
rhassing
Post by rhassing »
What happens if you don't specify the mib file?
So don't use the -m option.
Rob Hassing
