Top 5 Process consumption by CPU & Memory
prashanthan1987
How to add top 5 process details to CPU & Memory Usage alert for WIndows & Linux Servers. Please suggest
benjaminsmith
Re: Top 5 Process consumption by CPU & Memory
Going to do a little more research on this, but what plugin are you using right now for alerts on CPU and Memory. Also, which Agent (NCPA, NRPE) do you have installed on the remote systems?
If you're not sure of the plugin, the guide below will help you locate the check command and then post that to the thread.
Nagios XI - How To Test Check Commands From The Command-line
Benjamin
Benjamin
