Website Wizard: Cannot make SSL connection.
TBT
Post by TBT »
Using the Website Wizard to monitor a SSL Certificate, the check is returning: Critical CRITICAL - Cannot make SSL connection.
1. Manual check also fails
./check_http -H <server> -C 30,7 -p 443
2. Browsing with both Firefox and Chrome to the URL works with no cert errors.
Any suggestions?
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
benjaminsmith
Re: Website Wizard: Cannot make SSL connection.
Post by benjaminsmith »
Let's add the -v flag to the command line for verbose output to help troubleshoot the error. Please run the following and post the full output from the check command.
./check_http -H <server> -C 30,7 -p 44 -v
Also, please try the following version and post the full output as well. Thanks! Benjamin
./check_http -H <server> -C 30,7 -p 44 --sni -v
TBT
Post by TBT »
Assuming you meant 443, here are the results:
./check_http -H <server> -C 30,7 -p 443 -v
SSL initialized
./check_http -H <server> -C 30,7 -p 443 --sni -v
SSL initialized
SSL OK - Certificate '<server>' will expire on 2022-04-27 19:59 -0400/EDT.
benjaminsmith
Thanks for testing that.. Looks like adding the --sni option works.
--sni
Enable SSL/TLS hostname extension support (SNI)
https://www.monitoring-plugins.org/doc/ ... _http.html
TBT
Post by TBT »
benjaminsmith wrote:Hi,
--sni
Ah yes, this bit me once before! Issue resolved with Server Name Indication (SNI) flag.
benjaminsmith
Hi @TBT,
Excellent! We'll mark this as resolved. Feel free to open a new post if you have any new questions.
Benjamin
