NagiosXI upgrade to 8.3.1
sneha.irali
Post by sneha.irali »
Hi Team,
Can I directly upgrade the Nagios from 5.6.12/5.6.9/5.7.3/5.7.4/5.7.5(Since we have multiple instances running on different older versions) to 8.3.1..?
Or is there any upgrade path I will have to follow.
Regards,
Sneha Irali
UTE-COT
Re: NagiosXI upgrade to 8.3.1
Post by UTE-COT »
Hi, I have the exact same question with the addition that we are using the offline installation.
vtrac
Post by vtrac »
Hope you are having a good day!! ... :-)
You should be able to upgrade directly from 5.6.x/5.7.x to 5.8.3 (latest Nagios XI released version).
Please NOTE if your XI system is on CentOS 6.x, you can only upgrade to Nagios XI 5.7.5
Please, backup your system first:
Here's the upgrade instruction:
https://assets.nagios.com/downloads/nag ... ctions.pdf
If you are doing "offline" install/upgrade, please NOTE that only CentOS and RHEL are supported.
Download "offline" RPM package:
https://repo.nagios.com/?repo=offline
Here's the "offline" install:
https://assets.nagios.com/downloads/nag ... onment.pdf
Prerequisites for offline install/upgrade:
Regards,
Vinh
sneha.irali
please close the thread
vtrac
Post by vtrac »
Great!! .... locking thread ... :-)
