Nagios XI Deploy Agent(NCPA) on Unix with different SSH Port
Achillefs
Post by Achillefs »
Hello all,
Sorry if this topic has already been answered before but from my search I could not find anything related to it.
Basically, we have a Nagios XI setup in which we monitor a lot of Linux hosts using NRPE and we are thinking of switching to NCPA due to it being officially supported by Nagios themselves, and providing some things by default(monitor Services for example).
We have already tried the manual deployment of an agent it works like a charm.
What we would like to try now is the functionality of deploying a Nagios Agent through Nagios XI.
However, we noticed that it needs SSH access(which we can allow temporarily) but it tries only the default port.
So far I was not able to find a way to change the port the deployment task is using.
Can I somehow change that? I don't care if it gets changed for every server, I am fine with that.
Alternatively, is there any other way to achieve this? Deploying agents through Nagios XI itself seems like it will speed up the whole process by a lot.
Thank you very much!
ssax
Dreams In Code
Re: Nagios XI Deploy Agent(NCPA) on Unix with different SSH
Post by ssax »
You can edit this file:
/usr/local/nagiosxi/html/config/deployment/templates/ansible.cfg
Change this:
ssh_args = -o ControlMaster=auto -o ControlPersist=60s -o UserKnownHostsFile=/dev/null
To this:
- Change XX to the SSH port number you want to use
ssh_args = -o ControlMaster=auto -o ControlPersist=60s -o UserKnownHostsFile=/dev/null -p XX
Please note that this change will be reverted on an upgrade so if you upgrade you'll need to re-implement it.
I have submit a request to development requesting they add custom ports as an option:
FR: XI - NCPA Deploy Agent - Allow Custom SSH ports
Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
Achillefs
Post by Achillefs »
ssax wrote:You can edit this file:
Change this:
To this:
Sorry for my late reply. Just wanted to say thank you very much and confirm that indeed it worked like a charm!
benjaminsmith
Post by benjaminsmith »
Excellent! We'll go ahead and close this out.
Thank you for using Nagios!
