Monitoring Bandwidth using NWC Health Check
silentnoise
Post by silentnoise »
i have another problem.
I would like to check the used bandwidth on my cable-internet-connection usiung nwc health check in nagios to monitor the bandwidth on my Fritz!Box.
I used the Manual on:
http://www.schroeter-edv.de/?Dokumentat ... r_FritzBox
But it doesn`t work.
In this manual i have to copy the exec-file into dir:
sudo mv plugins-scripts/check_nwc_health /usr/lib/nagios/plugins/
but the directory /usr/lib/nagios does`nt exist.
There ist an Directory: "usr/local/nagios/libexec"
Is this the correct directory ?
Greets
silentnoise
Re: Monitoring Bandwidth using NWC Health Check
I´m able to run commands using command line:
/usr/local/nagios/libexec $ ./check_nwc_health --hostname 192.168.178.1 --port 49000 uptime --community "my Password"
it says:
./check_nwc_health --hostname 192.168.178.1 --port 49000 --mode uptime --community XXXXXXXXX
OK - device is up since 7d 15h 5m 16s, FRITZ!Box 6490 Cable (kdg) | 'uptime'=10985;15:;5:;;
So i know this is only the uptime, but i want to show, that nwc health check is running correctly.
rhassing
Post by rhassing »
I have checked out this plugin as well.
You should be able to check the interface usage:
./check_nwc_health --hostname 192.168.178.1 --port 49000 --mode interface-usage --community <passowrd>
The other checks described on the example page, memory usage and cpu load are not working very well
Rob Hassing
silentnoise
But how do i have to integrate it into nagios?
rhassing
Post by rhassing »
Edit /usr/local/nagios/etc/resource.cfg and add the your password
$USER4$=fritzbox-password
Add the config to nagios:
define host {
  use generic-host
  host_name fritzbox
  alias fritzbox
  address <ip-fritzbox>
  host_name fritzbox
  service_description Interface Usage
  check_command check_fritz!49000!interface-usage
Add the command to your command file:
   command_name check_fritz
   command_line $USER1$/check_nwc_health --hostname $HOSTADDRESS$ --port $ARG1$ --mode $ARG2$ --community $USER4$
The script is trying to write some data in /var/tmp/check_nwc_health
Make sure the nagios user is able to write in there.
Rob Hassing
silentnoise
Make sure the nagios user is able to write in there.[/quote]
How will i check this ?
silentnoise
Is here any failure ?
https://ibb.co/Rgmh3HF -> commands.cfg
https://ibb.co/X5y8xp8 -> fritzbox.cfg (host)
https://ibb.co/s2y5cz7 -> resource.cfg
https://ibb.co/b301WgK -> fritzbox.cfg (service)
silentnoise
I´m sorry.
I`m one step closer to finish :)
The script is running in nagios.
but it says:
https://ibb.co/pbYWkHn
silentnoise
Hello again :)
The script is running.
How can i change the output from bis/s to Mbit/s?
Greets
Speed
Speed
rhassing
Post by rhassing »
silentnoise wrote:Hello again :)
Greets
With the option -units MB it should be possible to change the output.
Rob Hassing
