running nagiosxi 5.8.1 on fresh redhat 8 system
however, when I do service nagiosxi restart I set error below
[root@orec2upm04 log]# service nagiosxi restart
Redirecting to /bin/systemctl restart nagiosxi.service
Failed to restart nagiosxi.service: Unit nagiosxi.service not found.
is there some instructions to start/stop set up service I'm missing?
Newbie Question : start stop
Re: Newbie Question : start stop
Hi
Try these:
sudo systemctl stop nagios
sudo systemctl start nagios
sudo systemctl restart nagios
sudo systemctl status nagios
Let me know how it works for you.
Try these:
matson-itops
yes, bouncing nagios core works fine.
is the nagiosxi deprecated?
[rxxx ~]# systemctl status nagios
● nagios.service - Nagios Core 4.4.6
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-05-25 09:34:09 PDT; 2s ago
Docs: https://www.nagios.org/documentation
Process: 1216085 ExecStopPost=/usr/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
Process: 1216083 ExecStop=/usr/bin/kill -s TERM ${MAINPID} (code=exited, status=0/SUCCESS)
Process: 1216089 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 1216087 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Main PID: 1216090 (nagios)
Tasks: 16 (limit: 94494)
Memory: 33.4M
CGroup: /system.slice/nagios.service
├─1216090 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
├─1216091 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─1216092 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─1216093 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─1216094 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─1216095 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─1216096 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─1216100 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
├─1216114 /usr/local/nagios/libexec/check_ntp_time -H 169.254.169.123 -w 0.5 -c 1
├─1216120 /usr/local/nagios/libexec/check_icmp -H 10.3.7.246 -w 3000.0 80 -c 5000.0 100 -p 5
├─1216123 /usr/local/nagios/libexec/check_icmp -H 10.8.7.4 -w 3000.0 80 -c 5000.0 100 -p 5
├─1216126 /usr/local/nagios/libexec/check_nrpe -H 10.102.90.49 -t 30 -c check_init_service -a sshd
├─1216127 /usr/local/nagios/libexec/check_icmp -H 192.168.0.24 -w 3000.0 80 -c 5000.0 100 -p 5
├─1216128 /usr/local/nagios/libexec/check_icmp -H 10.157.32.41 -w 3000.0 80 -c 5000.0 100 -p 5
├─1216129 /usr/local/nagios/libexec/check_icmp -H 10.157.32.125 -w 3000.0 80 -c 5000.0 100 -p 5
└─1216130 /usr/local/nagios/libexec/check_icmp -H 10.43.2.232 -w 3000.0 80 -c 5000.0 100 -p 5
Memory: 33.4M
Hi
There is no nagiosxi service. If there was one it must have gotten deprecated.
I reached out to the devs but haven't gotten an answer as to if it ever existed
or was deprecated.
Here is how to start and stop XI manually:
or was deprecated.
service nagios stop
service npcd stop
service mysqld stop
service postgresql stop
service httpd stop
service crond stop
service crond start
service httpd start
service postgresql start
service mysqld start
service ndo2db start
service npcd start
service nagios start
