Latest supported version of NCPA agent is 1.8.1
Here is ncpa.cfg
[listener]
uid = nagios
certificate = adhoc
loglevel = info
ip = 0.0.0.0
gid = nagcmd
logfile = var/ncpa_listener.log
port = 5693
pidfile = var/ncpa_listener.pid
# Available versions: PROTOCOL SSLv2, SSLv3, TLSv1
ssl_version = TLSv1
[passive]
uid = nagios
handlers = nrds,nrdp
loglevel = info
gid = nagcmd
sleep = 300
logfile = var/ncpa_passive.log
pidfile = var/ncpa_passive.pid
[nrdp]
token =UjdZYhrlDT7w8
hostname =vm.example.com
parent =https://nrdp.example.com
[nrds]
URL =https://nrdp.example.com
CONFIG_VERSION =0
TOKEN =UjdZYhrlDT7w8
CONFIG_NAME =
CONFIG_OS = None
PLUGIN_DIR=plugins/
UPDATE_CONFIG=1
UPDATE_PLUGINS=1
[api]
community_string =UjdZYhrlDT7w8
[plugin directives]
plugin_path = plugins/
.sh = /bin/sh $plugin_name $plugin_args
.ps1 = powershell -ExecutionPolicy Bypass -File $plugin_name $plugin_args
.vbs = cscript $plugin_name $plugin_args //NoLogo
[passive checks]
%HOSTNAME%|cpu usage = /cpu/percent --warning 20 --critical 30
%HOSTNAME%|swap usage = /memory/swap/percent --warning 40 --critical 80
%HOSTNAME%|memory usage = /memory/virtual/percent --warning 60 --critical 80Code: Select all
SSLError: [Errno 1] _ssl.c:507: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failurethanks
