Email notifications differ for some users
TBT
Post by TBT »
I've noticed that email notifications differ for some users. Below is a comparison with sensitive information adjusted.
These two users receive the same service notification via email but the message title and body differ. Notification Settings Management is using the Default Template. The expected notification is supposed to look like USER A, could this be related to the permissions a user has?
USER A
Title: PROBLEM Service Alert - HOSTNAME/User Count Vendor - HOSTALIAS is WARNING
Body: ***** Nagios XI Alert *****
Nagios has detected a problem with this service.
Notification Type: PROBLEM
Service: User Count
Host: HOSTNAME
Alias: ALIAS
Address: 192.168.1.1
State: WARNING
Info:
WARNING: Count was 4 users
Date/Time: 2021-05-25 14:44:07
Respond: https://site.com
Nagios URL: https://site.com
USER B
Title: ** PROBLEM Service Alert: HOSTALIAS/User Count is WARNING **
Body: ***** Nagios Monitor XI Alert *****
Service: User Count
Host: Vendor - HOSTALIAS
State: WARNING
Date/Time: Tue May 25 15:38:49 EDT 2021
Additional Info:
Please advise,
Nagios XI 5.9.1 (8 Servers)
Nagios Fusion 2024R1.0.2
dchurch
Re: Email notifications differ for some users
Post by dchurch »
If you change notification settings, you'll need to deploy those settings to users, since users have the ability to manage their own notifications.
Open Admin -> Notification Management, and "deploy" the notification preferences to the contacts/users affected.
TBT
Post by TBT »
Okay, so I've tried as you suggested, with the exception of deploying to all Nagios XI Users and Contact Groups as we need these notifications to be the same across the board.
I am selecting the Default Template then clicking Load Template prior to deploy, below are screenshots of related settings. After Deploy Preferences to all Users and Groups, the issue remains as initially reported.
I should also note we're still running XI 5.6.7 (incase of bug) which we plan on updating to current stable next month.
ssax
Dreams In Code
Post by ssax »
The difference in notifications can also be because they are using a different notification handler for the contact.
Please PM me a copy of your profile.zip from Admin > System Profile and also PM me the name of the contact that received them. It may be using the notify-service-by-email command.
