Hello Team,
We have recently upgraded the nagios logserver to latest version 2.1.8 . After upgrading to this version we are facing an issue while adding LDAP/AD users. After selecting distribution list inside LDAP/AD users, no users are listed.
NOTE -
Before upgrade this was working fine.
We have another logserver in the same network, which is still running on older version 2.1.4 where i can see the users in LDAP/AD distribution lists.
Best Regards,
bsanjay
After upgrade distribution list not displaying ldap/ad users
Re: After upgrade distribution list not displaying ldap/ad u
I'm labbing this up and will let you know what I find, I don't really see any changes in the change log that should impact it:
- The ones I do see I looked into and they shouldn't be related
https://www.nagios.com/downloads/nagios ... hange-log/
Hi ssax,
We have 3 nagios logserver setup in our organisation. We did upgrade on 2 and left prod. So now i see this DL's listing user on prod but not listing users on the both upgraded nagios logservers.
FYI, i was able to see list of users in DL's before upgrade and i did added AD users too. Please let me know if you need any more info from our side.
Best Regards,
bsanjay
Best Regards,
bsanjay
I'm able to replicate this, I'm looking for a solution and will update shortly.
Please edit this file:
Change this (line 123):
To this:
That would have been my fault as I submitted the merge request for this change, sorry about that! I've reported it to development.
/var/www/html/nagioslogserver/application/helpers/ldap_ad_helper.php
} else if ($type == "container" || $type = "nsContainer") {
} else if ($type == "container" || $type == "nsContainer") {
Hello ssax,
Thanks for your help. that worked.
Best Regards,
Sanjay Batkura
Best Regards,
Sanjay Batkura
Locking threadbsanjay wrote:Hello ssax,
Best Regards,
Sanjay Batkura
