Hi
Does Nagios XI monitor virtual memory utilization for windows servers. Also wanted to know how we can add the service to an added host. Please share the detailed process .
virtual memory usage in windows server
wipro-nagios-service
Re: virtual memory usage in windows server
If you use nsclient/check_nt you can get it by checking a counter
-v COUNTER -l "\\Paging File(_Total)\\% Usage","Paging File usage is %.2f %%" -w 70 -c 90
If you use ncpa I can't tell you how, but it should still be possible.
Thankyou
But my client is using ncpa.
Anyways got the solution.
