As of this morning we are no longer able to access our Nagios XI GUI. We can log into the CLI. I've tried restarting the httpd service but it immediately fails (See below). We have also tried restarting the VM multiple times with no luck
# systemctl status httpd.service
● httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2021-06-01 08:45:26 EDT; 17s ago
Docs: man:httpd(8)
man:apachectl(8)
Process: 9929 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 9929 (code=exited, status=1/FAILURE)
Jun 01 08:45:26 systemd[1]: Starting The Apache HTTP Server...
Jun 01 08:45:26 systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Jun 01 08:45:26 systemd[1]: Failed to start The Apache HTTP Server.
Jun 01 08:45:26 systemd[1]: Unit httpd.service entered failed state.
Jun 01 08:45:26 systemd[1]: httpd.service failed.
Unable to Access GUI
Re: Unable to Access GUI
Could you please provide the latest log files in /var/log/httpd to me?
You can compress them using:
tar cvzf logs.tar.gz *_log
Share the file in a private message and then reply to this post to bring it up in the queue
so we know it is available.
