NagiosCore had Extra Actions button
dslater
Post by dslater »
NagiosCore had an Extra Actions icon that let you go directly to the IP address as a URL. Click it and get the web interface on the device.
In NagiosXI is there a way I can click on something next to the host in the host listing and go right to the http://HOSTADDRESS of the device?
Even the Advanced>Show in NagiosCore does not have the Extra Actions icon . Thanks! :)
gsmith
Re: NagiosCore had Extra Actions button
Post by gsmith »
Here's a way to do that but it takes a little work.
When you are defining your host click on the Misc Settings tab and add the
value "http://$HOSTADDRESS$" to the "Action URL":
No when you look at the host on the "Host Status" page there will
be a "play" button that will take you to that url:
dslater
Post by dslater »
Thankyou thankyou thankyou. Works great!!!
I ended up adding that to my generic_host template for "Host Template" so now all my hosts have the play button and I can override the http:// with something else for a particular hostgroup if needed. like https:// or whatever :)
gsmith
Post by gsmith »
Awesome! Glad I could help.
Thank you
